Synergy Rack System - Need Help
CharlesWagnerRocks
Does the SYN2 Module Rack Mount allow me to run independent L/R channels for each module simultaneously into a power amp - OR - Do I have to purchase 2 SYN2 Module Racks and route each one independently to the power amp? I'd like to have my VH4 module in the R channel and my HBE module in the L channel, and run those at the same time into a Freyette 2:90:2 poweramp. I'm trying to keep this rig to 10 spaces or less so I can check it on Domestic flights.
To achieve what you want you'll need two SYN-2 since you can only do one module at a time.
The SYN-2 will output identical signals on its L and R outputs.
