Power amp choices
Rigs, Clips & Tones OH MY
panther_king
Post by panther_king » Tue Oct 19, 2010 10:16 am
I've also heard a ton of good things about the VHT/Fryette offerings.
SacredGroove
Post by SacredGroove » Tue Oct 19, 2010 10:35 am
panther_king wrote:I've also heard a ton of good things about the VHT/Fryette offerings.
The gold standard of power amps.
__Scott__
Jerome Allen
Post by Jerome Allen » Tue Oct 19, 2010 12:32 pm
+1 on the VHT 2/90/2.
RockManiac
Post by RockManiac » Wed Oct 20, 2010 1:16 am
rhequiem wrote:My RT2/50 gets some crazy hum going on channel 2, which is loaded with 6L6s right now. Any other RT2/50 owners get humming off their channels?
No humming on any of the channels of my RT2/50.
rhequiem
Post by rhequiem » Wed Oct 20, 2010 10:32 am
Yikes... I need to have mine looked at *again*, it sounds like. Any suggestions on what might be causing the humming? I bought a brand-new pair of 6L6 tubes from thetubestore.com for the 2nd channel, so I'd be surprised if it was tube-related. I did bias them and verified that they are in range...
RockManiac
Post by RockManiac » Thu Oct 21, 2010 3:26 am
You could also check the phase inverter tube for that power tube pair.
rhequiem
Post by rhequiem » Thu Oct 21, 2010 8:32 am
phase... inverter.... tube? lol
I'm still pretty new to the tube stuff - is that one of the 3 clustered tubes (the smaller ones)?
goldsparkletop
Post by goldsparkletop » Thu Oct 21, 2010 10:34 am
I've been using the VHT/Fryette 2/50/2 for seveal years now. It's not as expensive as most folks think. I paid $899 for mine brand new from Guitar Asylum, and that was not part of any special sale or anything. They maintain their resale value very well, though.
The main difference between the two VHT/Fryette models is that the 2/50/2 uses EL34s, while the 2/90/2 uses KT88s.
Randall RM4
VHT 2/50/2
Blackface, Plexi, Recto, 1086, Ultra Lead modules
Rocktron Xpression
www.krunchband.com
RockManiac
Post by RockManiac » Fri Oct 22, 2010 12:37 am
rhequiem wrote:phase... inverter.... tube? lol
Yes, the left little tube (looked at from behind) is the PI tube for the left pair of power tubes (channel 2), and the right one is the PI tube for the right power tube pair (channel 1). The preamp tube in the middle is the input tube (for both channels).
m0jo
Post by m0jo » Sat Oct 23, 2010 10:48 am
I haven't tried many other poweramps than my RT2/50. But I can say this: the combo of RM4 + RT2/50 sounds like it should!
I ran my RM4 through my Laney combo's poweramp for a while, it sounded good.. but can't hold a candle to the RT2/50!
On the GSP: I'm planning on getting one for FX and odd patches (where I want some extreme preamp setting not worth setting the RM4 up for).
I have an MX200 now and I do not recommend it.
The sounds are fine, but it does not have a killdry function.
So you could set the mix to 100% wet and use patch volumes right? Wrong, there's no volume per patch (only a global input volume).
Using it in the series loop is a no-go as well because there's a really annoying silence when switching patches (like the old RM4's but way worse).
The GSP does not have this problem, it runs on 2 AudioDNA2 dsp chips instead of the MX200's one AudioDNA (version 1).
According to Digitechs marketing that's 8 times as powerful. (apply a pinch of salt)
Salvation Mods Twinface, Mash-all+, Sloogie, Mu?eca, Shiver (Facelift), modded XTC, stock Recto
Randall RM4 - Randall RT2/50 - Randall RM22
TT-Cabs REX V212
www.sparkplugmusic.nl
