RH300G3 plus bass problem?
billymagnum
I noticed when playing with the bass eq on the dirty channels to over 5 the volume cuts to a lower level and then kind of just fades back to normal. Is this an amp problem or could I need to check the wires inside my cab? The cab is an older Laney from the 80's but Im not sure if this is a known issue with G3 plus head? Help?
