RG-80ES Power Switch
Posted: Sun Apr 18, 2010 5:06 pm
by brianm99
I just bought a Randall RG-80ES and the power switch broke off. Is replacing this an easy process?
Which replacement switch will work?
Posted: Tue Apr 27, 2010 3:22 am
by billymagnum
Posted: Tue Aug 10, 2010 10:36 am
by SaeCarnifex
And DP/DT of the same size should work, right? I have an RG80-es as well - did you end up fixing it?
Posted: Wed Jan 05, 2011 3:32 am
by Owner
billymagnum wrote:should work fine as long as the jack on the amp is fine...
http://www.championpedals.com/fs5j.htm
http://voodoomanswitches.com/component/ ... /vmcchk,1/
He's talking about the Power Switch, not FS..
How did you manage to break it anyway? :lol:
You need one of these, it's easy to replace btw..
Posted: Tue Jan 11, 2011 5:57 pm
by Led Hendriani
This weekend I just bought an on-off-on switch at Radio Shack for $3.99 but had to buy crimp on connectors for $1.99 since the unit has a screw in each leg and you can't solder onto the material the tab is made of.
Works great! Nice and sturdy!
A hair longer than I would have liked (touches the ground or table if I lay it on it's face) but a bit shorter than the POS plastic switch that someone had replaced it with prior to my trade. I guess I could always dremel off some of the tip if it were a real issue for me.
