RG80 es Channel Bleed
MikeKing
I have 5 RG80 amps 3 combo and 2 heads all of them have a problem with the Gain from the red channel bleeding over to the Green or clean channel. Does not matter if the foot switch is plugged in or not. Any help please
Hey Mike,
the most genius solution would be the RG Looper from ChampionPedals.com,
Since you've got 5 RG-ES's.. ask Trix if he could get a Splitter & RG-Looper custom made for you, it's worth every **** penny! You'll be sending your guitar signal to multiple amps, no bleeding, plus shared Fx Loop for anal gadgets like Eq's, Boost's, Delays.. etc..
Good luck, bro! 8)
