Grail module
strato62
Canada
Hi guys,
I know some of you have the Grail module.
I wonder if any of you could post a good hi-res pic of this module with the tube shield removed to see how it compares to the MrScary that it's pic was posted on this forum not too long ago, since neither schematic is available on this site.
It would be fun to compare the two.
Thanks, and keep on rocking those MTS/Egnater rig :D
Claude
Here ya go:
Oh .. the solder blob on the LED was me...I gut out the old LED and soldered a new one onto it's legs...LOL :D
Thanks for the fast reply :lol:
Awesome pic,
In fact at first glance it looks closer to an XTC by it's configuration than a Mr Scary. I thought they where (Mr Scary vs Grail) closer circuit wise.
I see there are some marks around c10, have you removed it ?
And , if you don't mind, can you tell us what color code is the resistor next to the cap?between r28 and that brown cap c29?
It's 470k (yellow,purple,yellow) on my XTC.
I'm also curious about the tone stack red capacitor which is c11 or c14 ...
Thanks in advance,
Claude
I've made no mods...I noticed on two of my (new) Modules marks (from rework?) around components....just q QC thing I guess...
I assume you mean r26 (between c9 and r28) - it's yellow, purple, yellow, gold so 470k +/- 5% ?
c11 is erm.....couldn't find it
c14 is 470 / 630 - presume that's 630V but not sure of power of 10...u or p ?
Dunno if this is relevant but the tube planar says "BRIT-TUBE" 100-101 REV 1.10 08/15/04
I have a Mr Scary but not an XTC...never really thought to compare them :D
Looks like R38 on my module is on it's way to burning out...wonder what value that is??? Can't read it :-(
Thanks a lot for those infos :)
I couldn't figure if the red tone stack cap was C11 or C14, now i know ...
So it's most probably 470pF, a standard value in tone stacks.
I noticed your soon to be out of this worls R38. :(
It's or should be ... the same value as it's neighbor R37, so it should be 4,7k.
Thanks again
Comparing Grail with MrScary was fun and instructive.
Here's my findings for now:
While the Grail mod pcb is very similar to the XTC pcb their values differ quite a bit.
I just finished comparing the Grail module pic to the Recto schematic found in the schematic section, and they're almost identical. Nothing too suprising here since they're both supposed to aim at Mesa's DR.
On the pic of the Grail module C3 looks to be 500pF, while Recto's value for this part is 2,2nF.
Can't tell either if C8,C9,C17 and C18 are 22nF like the Recto but by judging from the pic they look a little bigger, maybe 33nf ???
Could someone confirm these values please ??
I was wondering how hard it would be to convert a recto to a grail.
That would be killer if for nothing else but to try a grail before buying
one in a sense. Plus if I'm modding from one to the other and they're
sorta close I can come up with my own recipe even.
Shouldn't be too hard if you are able to handle a soldering iron without damaging the part, pcb and injure yourself.
If the only difference resumes to C3 it should be pretty stait forward and easy to get the required capacitor and replacing it to make it like the Grail module.
Now if C8,C9,C17 and C18 are of different value this would just require a little more work.
Would be nice if someone could post these values :roll:
I see some resistor changes too. I don't have the codes memorized,so I'll just name colors:
I Can't see R6(Prob same as R5), R9, R38(Looks burnt?), R37(Prob same as R38)
R16, R17, and R36 look the same as recto, but color is not clear enough to be sure.
Definitely Changed:
Recto Grail
R1:Yel-Pur-Brn-Gld R1:Brn-Grn-Brn-Gld
R2:Yel-Pur-Brn-Gld R2:Brn-Grn-Brn-Gld
R3:Yel-Pur-Brn-Gld R3:Brn-Grn-Brn-Gld
The OPamps look the same.
So what's left is Q1, Q2, (Though these are all probably just standard values making them the same) and the Caps.
C8, C9, C16, and C17 appear to be "Fatter" so are probably a larger value.
C6, and C13 look the same.
C2, C4, and C11 might be the Same (Probably are).
C14 appears different by if nothing else, packaging.
C3 is well documented and is a matter of taste.
So wow, it's a tweaked RECTO mod!
So we now know to change those 3 resistors, now we need the value of C8,C9, C16,C17, and C14. Possibly C3 to be complete.
Anyone Generous/Brave enough to take them out an measure them?
C8, C9, C16 and C17 are all same value - marking F223K b 630MPP1 so presumably 630V 22pf=0.022uF ?
C14 I posted earlier in the thread - 470pf / 630V
NuSkoolTone :
I think R5/R6, like Q1 and Q2 are only involved in swicthing circuit as well as R1/R2/R3 that are related to the H11F1 that are Bilateral Analog FET Output Optocoupler that are used in switching the module in or out the audio path between the first preamp stage and the power amp section.
JKD:
The 223 marking on the caps means 22nF = 0.022uF, so same value as the Recto mod.
So that means that the only difference would be the first cap ( C3) at the input of the module ....
I will try this cap mod as soon as i can get one, and i may give the R1/R2/R3 a try, just being curious, but i won't be able to make any comparison since i don't own both Recto and Grail.
Maybe someone on this forum have both and is willing to try to Grail his Recto or Rectified module and posts his impression, or better post a clip ??? :lol:
Thanks guys
strato62 said:
NuSkoolTone :
JKD:
Hey strato,
Cool you're in on this! Gotta say, I HIGHLY doubt that C3 is the ONLY change. I think the R1/R2/R3 Change is probably responsible for the Clarity some guys are saying vs. the Recto. Remember These resistors ARE used as mods in the clean modules, so there might be something to it.
Also where is some good documentation explaining markings on the caps relate to a certain value? IME markings on the cap often have nothing to do with the value and the only way to know is to pull it and check (Of course YMMV). Now if there are the SAME markings on multiple caps on the same manufacture, good chance they're the same value.
Plus those caps at C8, C9, C16 and C17 appear to be of the same type and are obviously bigger than the ones on the Recto. Honestly I'd be shocked if they were the same value. Since we know C14 (Thanks JKD), all we need to know for certain is the value of ONE of those caps since they're all the same. Then with little effort, those interested in the Grail can convert their Rectos!
Ok, I'm a dumbass. I found some info on the cap markings (Duh) here:
http://www.arar93.dsl.pipex.com/mds975/Content/components01.html
So for the the other knuckleheads there you go I guess.
So other than 3 resistors and a cap at C3, can that be ALL there is to it? I Mean everyone poops on the Recto and is raving about the Grail. Is this purely psychological?
Those 4 caps bugs me out though since they look twice as wide as the ones in my recto and appear to be the same type of caps. Weird!
What's also weird (to me) is the fairly meaty C3 Cap value .005, I always preferred the tightness of .001. Perhaps it's time to taste test again...
I'm just shocked it's 4 parts difference with new knobs and faceplate.
They sure bug me also,
At first i thought that the differences where those 4 fatter caps, but it doesn't seem to be the case.
Nothing prevents you to try 0.033uF though ....
or change that R31 for a 33k or a 56k, this will also have an effect of changing the way the tone stack eq your sound.
Changing C3 to a 500pF as it shows on the picture would change the way the Recto sounds for sure (recto is 1nF=.001uF=1000pF) since it will cut some bass going into the module and give a tighter attack giving a different feel to the module ....
Claude
Claude
Oh wait, so 500pf is actually HALF the Value of .001? (Doh!) Geez that IS tight. (I don't even have any caps lying around that are that small!) I would think it'll start getting pretty light in the low end no? You'd think they're be a compensation somewhere?
Perhaps it's the cap TYPE that's making a subtle difference. I tried a taste test with a switch between mallory and Orange Drops (715 & 716) of the same value and I could hear a subtle difference. Thing is the Cap Type appears to be the same as in the recto!
So really then, if everything we're postulating is correct, HOW is this a "new" module other than cosmetics?
The Grail sound is stated to be based on a Modern Recto sound...I'm not really surprised the values are same/similar. I'm pretty sure Randall will have just changed up a few values in the tone stack based on George's feedback and he will have gone yay/nay.
I bought my Grail expecting the Recto sound...as chance would have it, I'm getting a Recto module in soon too...this wasn't my plan but bought it as a package with an M4. :D
I 'tone' modded my Grail already tho...it has an eeeeeevil blue LED
I can't record for toffee but I could put up some quick comparison clips with same tone stack settings....hopefully this weekend.
'course I should've also noted under v1 on Grail it says
RANDALL 6/4/05
MODU RECTO
REV 1.10
:D
Great info, fellas!
I'm gonna have to read this more thorughly when I get the time, but for now I just wanted to post a link to a .0005uF cap:
http://www.mojomusicalsupply.com/item.asp?pid=17609&pg=44974&id=5164500
BTW, I've got some of these 470pf caps at home and they are probably "close enough":
http://www.mojomusicalsupply.com/item.asp?pid=96053&pg=44974&id=5168225
So after reading this thread, it sounds like R1, R2, & R3 to 150ohm & C3 to 500pf would change a Recto module to Grail specs?
I'm definitely game for giving that a whirl sometime.
BTW, I notice you've got JJ tubes in your Grail....are all Grails shipping that way from the factory?
