Rising Farce
Minty and monstrous, just not what I'm after at the moment.
- $--- shipped in the CONUS
You can become a Supporting Member which comes with a decal or just click here to donate.
If it is the settings you used in the picture, I can totally see not loving that module. The Herbert mode is more scooped. The Deep mode restructures the tones stack, impacting the mids and causing a drop in level that must be compensated for on the Volume. The module really opens up tonally when the Volume is set at 1:00-2:00. Try adjusting it and use your amp master as a volume control. You will have much better results that way.eyeball987 said:Are those your settings?
What is not working for you with the D tone?
I understand that some modules just don't work for some people but I have a theory that rings true for myself that I am looking for some back up on.
Jaded Faith said:If it is the settings you used in the picture, I can totally see not loving that module. The Herbert mode is more scooped. The Deep mode restructures the tones stack, impacting the mids and causing a drop in level that must be compensated for on the Volume. The module really opens up tonally when the Volume is set at 1:00-2:00. Try adjusting it and use your amp master as a volume control. You will have much better results that way.eyeball987 said:Are those your settings?
eyeball987 said:It's all good! I have just found that on the many modules I have had, modded or not, running the gain all the way up makes the tone and feel completely fall apart. That is the backup that I was looking for to tell myself that am not crazy.
Rob probably gave the best advice.
On another note, I have found it rare to be able to go super heavy without using a boost and keeping the module gain lower than 3:00. Usually between noon and 1:30 on the gain knob actually. YMMV.
Edit: I have not played the D-Zilla but would love to try one. I just need to find $300 to by yours!
audiomidijace said:Having just switched from using RM50 combos to RM4 preamps, it seems that my module volumes need to be higher to get same output level. Anyone care to comment on this?
Rising Farce said:Revelations of the Day:
1. Some modules--including the Zilla--do indeed sound much better with the (module) volume up.
2. Others--my HBE, in particular--don't seem to exhibit much of a difference.
3. The difference seems to be less pronounced on the combos than on the head, where it's drastic.
4. Specifically, running the head master higher adds a ton of bass, so turning it down does require a fair amount of compensatory knob twiddling to put the "thump" back. (Turning up the Density control helps a lot.)
5. On the flipside, the clarity improves noticeably with the head master at a lower setting.
Oh, MTS, you are a wily mistress.
Enter your email address to join:
