Hamner1 said:I have not. Unfortunately the C2 pedal doesn't have a midi cable socket connection, just the ethernet to connect it to the GSP.
Send MIDI Prgms
By setting the Send MIDI Prgms option to ON, MIDI program change messages will be sent out the GSP1101?s MIDI Thru jack when presets are changed
on the GSP1101 either by the front panel Edit/Select knob, by selecting them in the editor librarian, or when the GSP1101 receives a program change message via MIDI.
These MIDI program change messages do not get sent out of the GSP1101 when Send MIDI Prgms is set to OFF. This option is set to OFF from the factory
Merge In > Thru
By setting the Merge In>Thru option to ON, incoming MIDI CC and program change messages are routed out of the GSP1101?s MIDI Thru jack to other connected MIDI devices.
These messages do not pass through the GSP1101 when the Merge In>Thru is set to OFF.
This option is set to ON from the factory.
To configure the MERGE IN > THRU option
1. From the Preset screen, press the Edit/Select knob.
2. Turn the Edit/Select knob until the MIDI menu is selected and press the knob.
3. Turn the Edit/Select knob until Merge In->Thru is selected.
4. Press the Edit/Select knob to turn the option on or off.
5. Press the Back button to return to the previous menu
