Vybe Deluxe clip
withmittens
Beacon, NY
For what it's worth, here's a filthy looping clip of me using a lap steel through a Ditto Looper, a DLS overdrive an Echorec and an OR 120 pedal into a Vybe Deluxe. there's some clean sounds in there as well as some overdriven sounds. I don't know what this says except that the Vybe can take a lot of stuff and put out a range of sounds. I made this in one take, loop after loop, so it's kind of dirty and sloppy.
http://soundcloud.com/it-happens-to-me-and-you/vybe-deluxe-lap-steel?utm_source=soundcloud&utm_campaign=share&utm_medium=facebook
Thanks Johnny, it's messy as hell, really. Just wanted to have a go with the looper. need to get my mic placement and levels worked out
I can see what you're going for dude.. very nice style and playing.. all that other stuff (levels and such is secondary) you've got the touch and feeling !
Rock On Bro!
\m/
Thanks for the nice comments. much appreciated
An OR pedal is a newer version of the Orange Peel that can be found at http://www.olcircuits.com/olc_orangepeel.html
The Orange Peel design was worked out by Brian Tremblay who runs runoffgroove and licensed the design to OLC. He redesigned this circuit into what he calls an Orange Blossom and is a more refined amp in a box type design modeled after the orange OR120, or V2.o of the Orange Peel. I got it from Brian who build pedals under the Sonic Salvo name. He never released this pedal but builds them if asked. It does a lot of variation on that sound but will do a pretty convincing OR roar, complete with the FAC switch.
