PSA regarding tubes
Jaded Faith
Hamilton, NJ
I have noticed several modules sent in recently for mods or repairs that had tube-related issues. I wanted to post this info in a sticky after emailing it several times this week.
I noticed several Tung Sol's being used in V2 (the tube on the right). That is the cathode follower (CF) position. Anything manufactured by New Sensor (ie: Tungsol and Mullard reissue, EH, Sovtek etc) have a lower heater to cathode rating. They will either completely die, go half gain/volume or fluctuate in volume if used here. JJs, Chinese and NOS preamp tubes will be fine for the CF position.
This is a tube manufacturing issue and has nothing to do with the modules or amp involved. It is not an MTS-related issue, it has to do with using the New Sensor tubes in any CF circuit. A CF stage subjects the cathode to high voltages and these tubes can not handle it. It may not cause an instant issue, but is will fail prematurely. Most of the donors sent in lately with a Tung Sol on the right have tested failed or worn with the CF side of the tube as the bad side.
This is a well-documented issue for several years now.
Thanks Rob! This is critical information to know!
This explains why the Mullard reissues I tried craped out one after the other when I tried them once and swapped their positions and tried again; first half volume then no volume.
This is good information to share, thanks. One question, where do Ruby Tubes fit in this description? Chinese, I assume.
Also, I believe you use an Orange tester, as do I. At what point (#) do you consider a tube weak and replaceable?
Ruby's are Chinese. The main New Sensor brands you need to be aware of for this issue are Electro-Harmonix,Tungsol, Svetlana, Sovtek, Mullard and Genelex. I go through hundreds of tubes a year here and the Mullards and the Tungsols are the most sensitive to this. Mullards typically die instantly in this scenario.
The Orange VT1000 is what I use for simple day-to-day testing where my better testers aren't needed. That grades on a scale of 0-15. Any reading of 0-3 will fail the tube and it's garbage. I won't return these tubes to you and try to call or email immediately. A reading of 4-5 is considered worn and this tube has a very short life left with deteriorated performance. It should be replaced ASAP. I consider a 6-9 typical gain and healthy. Anything at a 10 or above is what I consider high gain.
I had several Sovteks (and a couple EH) in the V2 position when I went through my modules yesterday. All but one of these tubes tested good, if not incredibly high, on my tube tester. All these modules (tubes) have several, upon several, hours on them. I did swap them out and moved some Sovteks to V1 in some modules (put the rest in inventory), replaced V2 w/ Ruby HG/HG+, JJ or Chinese. Is there an explanation of why the Sovteks would have lasted so long in V2?
Also, where do Svetlanas fit in the mix? Are these New Sensor tubes?
Just to make sure, If I am looking directly at the face plate v2 is on the right, correct?
Hmic10: V2 on the module is on the right when looking at it from the front.
Drew: Sovtek are among the most stout of the New Sensor offerings. There are no hard and fast rules except that the potential for failure exists from this manufacturer. I will confirm from personal experience and several customer reports that the Mullard tubes are the ones that die the quickest. Many reports of these dying instantly in a CF position. I would say Svetlana and Tung Sol are the second quickest to die consistently.
Matt: There's no general place I can refer you to, but a quick Google search will show hundreds (if not thousands) of sources for this info all over the Internet over the past decade. It's well-documented for many gurus in the industry. You can find tons of posts from everyone from Friedman to Fortin amongst others all over Internet forums. Several Tube sellers will also mention it. It was a topic of discussion at the LA Amp show last year on our high gain wizards panel. I would say is being common knowledge since at least 2007.
This makes sense since I lost several Tung Sols (gold pinners too) and EH in that V2. It would appear some old NOS, the Chinese tubes and JJ's arent affected here...At least in my rig.
Drew: Sovtek are among the most stout of the New Sensor offerings. There are hard and fast rules except that the potential for failure exists from this manufacturer. I will confirm from personal experience and several customer reports that the Mullard tubes are the ones that die the quickest. Many reports of these dying instantly in a CF position. I would say Svetlana and Tung Sol are the second quickest to die consistently.
Thanks, Rob. I have found several websites, reviews, etc. that all are very clear in NOT USING these tubes in CF positions. I guess I should consider myself lucky that I didn't lose more nice tubes.
A bunch of Ruby and JJ on order as I used most of my supply on the project yesterday.
Looks like I am going to need to order up some JJ, Ruby, etc.
where did you order from drew?
I went with ValveQueen.com for the Rubys and Ruby/JJs. She has quite a nice variety at various pricing levels.
I got the Shuguang and straight JJs from tubestore.com.
I usually order from Doug's, but he sent me a couple bum tubes last time according to my tester and all he had to say was "they're guaranteed to work for their intended application." So, that's it for good ol' Dougie.
I have a very good record on any orders through The Tube Store and Tube Depot as far as consumer outlets go. Valve Queen is great as well.
If you are buying JJ's specifically, email Bob at Eurotubes and tell him Rob at Jaded Faith Mods sent you over. I use him for critical orders. His stuff is consistently the best tested before it ships out and my own checks here have confirmed it. I have the highest confidence in his JJ supply out of all my vendors.
Thanks for posting this Rob. I've been having heaps of the said problems with my LoneClean and even though I had been changing the tubes I had consistently been putting one of the sovteks in V2. Once I changed it to one of the better tubes in V2 it's gone back to being a gig worthy module.
I had a new JJ HG+ from Valve Queen in the V2 position go out last night...
I thought the JJ was safe there but apparently not? When the Mullards died there, it was just a huge drop in volume but last night I was jamming and it was sounding off the hook and then dead instantly! No sound... Never had it happen like that before.
I popped out the module, pulled the JJ in V2 and tested it in the Orange VT1000 and sure enough... it didn't get halfway through the test and came back with a big FAIL. :?
I wouldn't worry about that one Marco, tubes can (and do) fail. Laura is great and her tubes are excellent. It just failed before it's time. I stock and use more JJ preamp tubes than any other and they are extremely reliable, quiet and consistently the highest gain on average.
As a side note story, I just had an amp come back into the shop Tuesday that was picked up last Friday. One of the brand new Sovtek 12AX7's had a small base pin fracture that went unnoticed until he drove it home and fired it up. The crack became a vacuum leak and the tube died. It happens.
I had just put the tube in the night before so it was fresh from VQ. This batch was the best batch of tubes I think I've ever ordered; I tested them all when I got them and they all tested great and better than anything I had on hand.
The good news is I was going to put that one in my VHT 2502 and I'm glad I didn't! That's a lot of screws to get the top off! :lol:
