ricky said:
Thanks Rob. That being said, anyone out there have any suggestions in making the stock Plexi more "plexi-ish?"
My opinion: there is little validity in the claim that just changing components with "better quality" components (1% tolerance resistors, vintage capacitors, etc) will improve your module. There is a lot of hype out there... If you like the stock plexi, keep it. Now, you can modify it to be more flexible, keeping all the stock sounds but adding a couple of switches to round the mids and bottom, increase the gain range with an extra stage, broadening the eq, etc, but I don't know if that qualifies as a base mod.
I like the stock plexi a lot. In fact, I think nearly all stock modules will do at least one thing well with the right power amp/cab setup. My complaint is more with their lack of flexibility than with how they do what they do.
