Do you juice before your mods? What flavor dirt do you like in front of which mods?
I've only recently started down this rabbit hole and can already see I need to re-evaluate what some modules are capable of with a little help out front.
My most recent addition is a TC Nova Drive, and it's added a ton of functionality to my RM4 set-up. It's an analog overdrive and distortion dual pedal that can save 18 presets and switch the pedal order including running them in parallel. Combined with the MIDI channel switching on the RM4, I can switch from a straight in Twinface tone, to an OD boosted Twinface, to a parallel OD/clean blend boosting the Grail module, to a straight-in Voxless break-up tone, to a clean boost that pushes the Voxless gain into lead territory.
Really like the Sparkle Drive style clean blend control on the OD side, especially when running the distortion in parallel. Favorite feature by far though is being able to hit save when I get it dialed in just right for a module.
It's making me re-evaluate a lot of mods based on how useful their lower gain settings are, as I can push them into higher gain with several flavors now. The Voxless and Grail are two that really work well, while my old favorite SL+ variants don't have much flexibility. Next two modules going in the rack are my JF Mark X and XTC to see what they can do when juiced!
So now I'm wondering what other modules out there play well with dirt in front to cover lots of ground? Any favorite combos?
