rm4
renato
Italy - Treviso
stupid question, maybe already asked hundred times... i can't find anything in internet about adding one hardware switch to enable rm4 to drive the second channel of a dual channel module...
it so difficult in your opinion?
Renato
Not an option. The switching logic is a function of the switching hardware in the unit and the code programmed onto the MIDI chip. The RM4 has neither the hardware to do this nor the code programmed on the logic chip to perform this function. There is no "switch" you could add to rectify these issues.
Indeed, the solution appears to be to add a switch to every dual channel module....or buy an M4 :)
You are 100% correct sir. The module switch changes nothing on the RM4, it simply internally re-routes the signal in the module itself.
