Can't get on site using IE, can using chrome..
Post new topic   Reply to topic    MTS Forum Forum Index -> MTS Forum News & Annoucements
warlok
PostPosted: Fri Mar 06, 2015 6:47 am    Post subject: Can't get on site using IE, can using chrome.. Reply with quote
When I try to get on the site using IE version 10 I think (work PC) I get this:
Fatal error: Call to undefined function: str_split() in /home/grailton/public_html/mtsforum/index.php(1) : regexp code(1) : eval()'d code(1) : regexp code on line 1
I can access it using chrome and this is the only site that has this problem.
Any ideas??
Jackson, Charvel, Ibanez. RM100, RM50 (both Foglifted), JF Erect, MarkX, '59RR, XTC, Stock KH1 & 1086. Carvin 4x12 with G12T-75's/V30's X-pattern, Randall R212CS with older Eminence OEM's
tschrama
PostPosted: Fri Mar 06, 2015 7:44 am    Post subject: Reply with quote
been that way for weeks allready. I'm using firefox since...
my small atelier called 's-Gravenmade | Follow me www.sgravenmade.com | Join my Amp Building Workshop 14 april 2018
Good deals with: C2ply, BenMesaBoog, YouguitarHero, nitrous12, kylendm.
View user's profile Send private message Send e-mail AIM Address
ned
Site Admin
PostPosted: Sun Mar 08, 2015 6:11 pm    Post subject: Reply with quote
Made some changes. Let me know if the problem persists.
Ned
Grail Tone - Amp Settings
My Rig: Egnater Mod 50 1x12 Combo w/ VX and SL2 modules
FX: Digitech GSP1101, RM4 w/ SuperV, JTM45, Plexi, XTC, KH2, TB
Personal Web Page
tschrama
PostPosted: Mon Mar 09, 2015 1:14 am    Post subject: Reply with quote
Problem is still there with IE:
"Fatal error: Call to undefined function: str_split() in /home/grailton/public_html/mtsforum/viewtopic.php(1) : regexp code(1) : eval()'d code(1) : regexp code on line 1"
With Firefox there is no problem at all.
warlok
PostPosted: Mon Mar 09, 2015 6:25 am    Post subject: Reply with quote
Yeah, still no good using IE for me too.
suphuckers
PostPosted: Mon Mar 09, 2015 6:44 am    Post subject: Reply with quote
Fatal error: Call to undefined function: str_split() in /home/grailton/public_html/mtsforum/common.php(1) : regexp code(1) : eval()'d code(1) : regexp code on line 1
Same for me
"Dude, you're easily the gnarliest guy I've seen around here in years"
59' Sears Wish Book Cowboy Guitar w/ Christmas Box, AXL Acoustic Guitar Pickup w/ E-pin Jack, Marshall MS-2 1/2 Stack Classic. ohhh, and some modules.
ned
Site Admin
PostPosted: Mon Mar 09, 2015 5:49 pm    Post subject: Reply with quote
Made more changes. Let me know if there are more issues.
Personal Web Page
suphuckers
PostPosted: Mon Mar 09, 2015 5:57 pm    Post subject: Reply with quote
Fatal error: Call to undefined function: str_split() in /home/grailton/public_html/mtsforum/includes/constants.php(1) : regexp code(1) : eval()'d code(1) : regexp code on line 1
tschrama
PostPosted: Tue Mar 10, 2015 1:02 am    Post subject: Reply with quote
Sorry, still the same error in IE.
warlok
PostPosted: Tue Mar 10, 2015 6:41 am    Post subject: Reply with quote
me too.
MarcoR
PostPosted: Tue Mar 10, 2015 8:15 am    Post subject: Reply with quote
IE 11 has caused some issues with some of my web applications and forcing emulation mode has worked in some cases. I thought I'd check here but it did not make a difference.
However, for a workaround, if you want to use IE with this site, hit F12 or go to Tools > F12 Developer Tools > Emulation and change "User agent string" to Google Chrome or Opera. Then you will not get the error.
I'm not a PHP developer otherwise I could tell Ned how to fix it. Sad
edit: A quick google search turns up lots on this error. "str_split() is only available in PHP5, so I suspect the problem is you're running PHP4.x. Try using explode() instead."
Ned, what version of PHP are you running?
Synergy: SYN2, Friedman DS, HBE
Self Modded: Egnater B'Man, SL2X
Amps: VHT 2/50/2, RM50, Landry LS100 G3, Splawn Quick Rod, Marshall 6100LM
ned
Site Admin
PostPosted: Wed Mar 11, 2015 7:58 am    Post subject: Reply with quote
Site is running php 4.x
I keep debating about upgrading the server but it's a crap ton of work since much of the code will need to be re-written for PHP 5. The forum upgrade is the easy part.
Personal Web Page
SickPunk
PostPosted: Tue Jul 07, 2015 7:58 am    Post subject: Reply with quote
Still can't get to the page with IE 11.
Lynchbox RM100LB, Brahma, Mr Scary, The Grail, The Judge. Randall NBKing 100.
Post new topic   Reply to topic    MTS Forum Forum Index -> MTS Forum News & Annoucements All times are GMT - 6 Hours
