common input preamp tube question ?
Post new topic   Reply to topic    MTS Forum Forum Index -> Gigmods Module Mods
drsakky
PostPosted: Thu Jul 07, 2011 2:54 am    Post subject: common input preamp tube question ? Reply with quote
Hello, I am not sure if this is the right place to post but I have just bought a rm100 second hand , the amp has been used a lot but the seller had it retubed not too long ago with some Mullard el34's. I have since then sold the old modules and got 3 new ones ( I play high gain ) but it does not look like he changed the three 12ax7 common input tubes that are in the head on the left side. Do these have a effect on the sound they are pretty old.
To change these do you have to do any bias or is it just a matter of take them out and put new ones in, I dont know a lot about this sort of thing ?
Also what 12ax7tubes would you recomend ?
Thanks
Shinozoku
PostPosted: Thu Jul 07, 2011 6:38 am    Post subject: Reply with quote
Pull em out, put new ones in. No biasing required.
The one closest to the guitar input is the input tube. I like a TAD 7025 or Tung Sol 12AX7 here.
After that, is the FX loop buffer. This one doesn't matter too much, but a Tung Sol will work.
The one closest to the power tubes is the phase inverter. This is the last gain stage processing the signal before the power section. I will ALWAYS recommend a nice NOS 5751 in there (Phillips, RCA, GE, etc.). Tung Sol will work though.
RM100M w/ Tung Sol 5881's
Blackface(self modded), Ultra Lead, SL+(out of commission), Ultra XL (self modded)
Vader 2x12 Cab
Edwards E-AL-128 with a Seymour Duncan JB
View user's profile Send private message MSN Messenger
Ogopaiwa
PostPosted: Fri Sep 11, 2015 2:11 am    Post subject: Reply with quote
I read it this bad dream.
Post new topic   Reply to topic    MTS Forum Forum Index -> Gigmods Module Mods All times are GMT - 6 Hours
