galao
It was converted to take Egnater dual channel modules.
Channels are either switchable on the front or using the footswitch.
Specs:
18 watts
EL84 power tubes with little use
Master "Density" & "Presence" controls
Footswitchable Tube Boost function
"Boost Gain" control for desired distortion
"Boost Level" control to adjust the boost volume
Series effects loop
XLR "Mic Eliminator" direct output
8/16 ohm ext. speaker output
Slave output
Rear panel power tube bias test points
As the amp runs on 100-240V, it can be used worldwide and I`ll ship it to any place you like. I´m located in Berlin, Germany. Shipping to foreign countries will be between 25-65 Euros. It comes with the original Randall footswitch.
You can send an email to [email protected] if you have any questions or want a shipping quote.
Thanks,
Paul
Specs:
18 watts
Series effects loop
Slave output
Thanks,
Paul
