T2 question
terminator2
If I plug my T2 into a stereo cab with a speaker cable from each speaker out into separate 8 ohm loads on each side of the cab, will the amp be putting out 300 watts (150 per side) like when I use a single 4 ohm load, or will it be putting out 200 watts (100 per side) like a single 8ohm load? I'm getting my ohm/watts ratios from the back of the amp instead of the website btw.
