RM4 Multiple Outputs
JMMP
PostPosted: Thu Jan 12, 2017 7:31 pm    Post subject: RM4 Multiple Outputs Reply with quote
Has anyone used the pre loop output of the RM4 while also using the post loop (stereo) outputs? Does it work? Are there any major sound deficiencies. I am thinking I can save a little space if I use the pre-loop output for my dry sound, and use the post loop outputs to drive my effects units, then sum dry and wet in a mixer. I will try to try this later tonight to see if it will work, but figured I would ask around as well.
Thanks for any info you may have!
Good Deals with: lintycreep, msm222, gtrlw
Capt_Tippy
PostPosted: Thu Jan 12, 2017 8:13 pm    Post subject: Reply with quote
That's kinda the point of the parallel loop. The effects knob acts as your mixer soooo......
Moral of the story, buy extra tubes, and don't pay up charges. Good luck, cause tube buying is a crap shoot.
You're correct. I probably have no idea what I'm talking about. I'm not even sure why I bothered to say anything in the 1st place.
JMMP
PostPosted: Thu Jan 12, 2017 8:19 pm    Post subject: Reply with quote
I have a Lexicon and an Eventide unit, both of which I intend to run in stereo. The dual outputs (post loop) would be perfect to drive these two units, which would then be summed in a stereo mixer with the dry signal.
JMMP
PostPosted: Thu Jan 12, 2017 9:50 pm    Post subject: Reply with quote
An update in case anyone else is looking for the answer: It works just fine. I took the pre loop output of the RM4 straight into my mixer, and the post effects loop outputs into the L/R inputs of the Eventide (just for this test, in the future it will be one input per effect unit, with a Y cable) and the Eventide's outputs into the mixer, and from the mixer to a stereo power amp and stereo cab. The eventide received plenty of signal (actually had to pad the input by 6dB) and it all sounded great!
