RT2/50 in 100 watt mono mode?
Discussion for both Egnater & Randall modular amps
withmittens
Post by withmittens » Thu Mar 16, 2017 8:57 am
I can't find any mention of it int he lit but I think I've read about it somewhere?
is it only 50 watt per channel in stereo or 50 watt mono........?
I had thought I could run it in 100 watt bridged mono
RM22, RM4
CrazyNuts' Dirty Sanchez, DuoPlex, Selma, Supra, Twinface, Evil Kitty, CC30, XTC
SG, LP Std., Strat, TELE
audiomidijace
Post by audiomidijace » Thu Mar 16, 2017 10:32 am
From the manual:
Switching/Stereo switch: The RT2-50 has 2 modes of operation, 100 watts of Stereo operation, and 50 watts per channel in mono Switching mode. When assigning a specific channel to your guitar preamp, you must use Switching mode. Stereo mode can be used for running multiple cabinets at the same time. Tip: Switching mode can also be used with multiple cabinets, so you can switch back and forth between cabinets. Simply connect to Channel 1 input of your RT2-50 from your guitar preamp, and in switching mode, run a speaker cable from both Channel 1 and Channel 2 outputs to sounds out of different cabinets and switch between them.
RM50, Orange PPC412 w Celestion V30s.
Modules: SG-MK22, JF Twox .
Pickups:MotorCity & BareKnuckle
Dunlop 95Q Wah, TC Nova System, Wampler Tumnus
AVID ELEVEN RACK & Atomic Amplifier 12
Transactions:Lots!
max44
Post by max44 » Sun Dec 03, 2017 4:14 am
You cannot "bridge" the RT2/50 to have a 100w mono, but you can put 2 pairs of identical tubes and have a 2x50w stereo with your favorite tubes ...
