Noisy 1086 stock module
Post new topic   Reply to topic    MTS Forum Forum Index -> Signature Artist MTS Models
sschultz5178
PostPosted: Thu Oct 29, 2015 7:32 am    Post subject: Noisy 1086 stock module Reply with quote
Finally got the chance to play the stock 1086 module I scored off of ebay. First attempt was through a 94 strat with SCN pickup and was noisy even while playing. So much so it was unlistenable.
Next was an Ibanez RG with Super Distortion pup and it was fine. Of note the RM 100 is currently loaded with a Mr Scary and XTC both with the gain pushed up and had no issues with the above mentioned strat.
This was all at bedroom volume levels running straight into the head from the guitar.
When I get off my lazy butt and set up my board and noise gates I know much of this will be fixed. However I don't know why the strat was so noisy when playing.
Any ideas?
Professional Hack Guitarist
RM100, blackface, Top Boost, Mr. Scary, 1086 & XTC into a Peavey 5150 4 x 12.
Guitars way too many to list
View user's profile Send private message Send e-mail
azrael
PostPosted: Mon Nov 02, 2015 8:12 pm    Post subject: Reply with quote
SCN are supposed to hum canceling. I would say that there's probably something wrong with the wiring in that guitar.
Don't rely on a noise gate for everything. Eliminate noise as much as you can before adding one, I always say. That way your gate can less of an effect on your overall tone.
CrunchBunch
PostPosted: Tue Mar 08, 2016 9:37 pm    Post subject: Reply with quote
I've had noise issues with an Ultra and Brahma module and in both cases it has been a bad pot causing the noise. It seems some of these modules are prone to having the pots crack. When this occurs, its often associated with lots of white noise or a squeal. If any of your pots are crackling, then it may be worth replacing them.
Even if they are not, its worth pulling the module apart so you can remove the face plate, re-insert the module bare into the amp and then by tapping the various pots with a pencil you can identify the noise causing culprit.
The 1086 should not be excessively noisy.
hotdog09
PostPosted: Thu Apr 20, 2017 4:46 am    Post subject: Reply with quote
It is interesting.
allensurface
PostPosted: Sat Dec 30, 2017 2:35 pm    Post subject: RE: Reply with quote
Thanks for the shared post! It was interesting to learn more about your thoughts on this matter!
http://bigpaperwriter.com/blog/abigail-williams-essay
Post new topic   Reply to topic    MTS Forum Forum Index -> Signature Artist MTS Models All times are GMT - 6 Hours
