Rm100 midi help with boss es5
Kainer
PostPosted: Sat May 27, 2017 10:31 pm    Post subject: Rm100 midi help with boss es5 Reply with quote
Hey guys, had my amp for a while now,
I'm running a boss es5 midi looper and wanted to to know, the 7 pin connector still required to run the midi?
On another note my normal midi cable doesn't want to plug into the es5 at all which is annoying
Randall rm100 combo
Randall Plexi
Jaded faith user sonic
Randall XTC
Randall super lead
View user's profile Send private message AIM Address
Bradle
PostPosted: Sun May 28, 2017 3:37 am    Post subject: Reply with quote
I'm pretty sure if the midi pedal you're using has its own power supply then you only need a 5 pin cable. I read on here somewhere that the extra 2 pins just supply power to the original Randall pedals.
bryantabuteau
PostPosted: Sun May 28, 2017 4:48 pm    Post subject: Reply with quote
I use an RM-100 with a Boss ES-8, standard midi cable. Works sweet.
RM100 - Clean, SL+, Recto, Blackface, Salvation JJ Dirt, JF Mark X, Salvation Legend, Salvation Dreadplate
