MIDI part 2
Post new topic   Reply to topic    MTS Forum Forum Index -> Rigs & Tones
wesman11483
PostPosted: Sun Jul 16, 2017 7:07 pm    Post subject: MIDI part 2 Reply with quote
Hey all...got dune GREAT advice last time for incorporating MIDI into my rig. As most of us are so prone to do, I'm tweaking it...but actually paring it down...
I have an 8 button MIDI switch (3 banks of Cool...I want to use it to run my RM4 and my H9. Here's the rub: H9 is 5 pin. I have an adapter cable with phantom power for the footswitch already...so qoukd it be best to
A) go MIDI in to RM4, then thru to H9 using the 7 to 5 cable (minus the power) or
B) go MIDI in to H9 and then thru to RM4 with a 5 pin cable? What would I be losing?
Thanks in advance!
Randall RM22: Jaded Faith Voxless, Salvation Dreadplate
Deals with Firebird V, blacksun, Ty, and others...
webrthomson
PostPosted: Mon Jul 17, 2017 5:07 am    Post subject: Reply with quote
The only difference between a 5 and a 7 pin midi cable is the power - if you dont need the power then use a 5 pin cable.
MarcoR
PostPosted: Mon Jul 17, 2017 5:52 pm    Post subject: Reply with quote
If you're phantom powering the controller with the RM4, then go with option A.
Synergy: SYN2, Friedman DS, HBE
Self Modded: Egnater B'Man, SL2X
Amps: VHT 2/50/2, RM50, Landry LS100 G3, Splawn Quick Rod, Marshall 6100LM
wesman11483
PostPosted: Sat Jul 22, 2017 1:30 pm    Post subject: Thanks Reply with quote
Thanks guys.
Got it all wired up, but being MIDI slow is coming up again...seems a reprogram us needed.
Anybody have experience using the RM4 and H9 together with one controller?
Post new topic   Reply to topic    MTS Forum Forum Index -> Rigs & Tones All times are GMT - 6 Hours
