trimix said:I'm guessing the Fenders are the only remaining Egnater design as they still feature the D/S switching from his last run of modules:
DUAL<>SINGLE SLIDE SWITCH:
The T/DLX module includes a switch used to allow the new Synergy modules to be used in older single channel Egnater and Randall modular amps/preamps that do not accept the dual channel modules. This allows access to either of the module channels when that slot is turned on. You will still not be able to switch between the two channels due to the limitations of the older hardware. You can set it so either module channel one or module channel two will turn on when the slot is selected. Set to Dual when using the module in units that have the switching circuit to access both modules. If you are using a single channel only amp/preamp, setting to DUAL will make the bottom module channel active. Set to Single will cause the top channel of the module to come on when selected.
chrismilne said:Also it seems that every module pretty much has the same knobs, it would be nice to see them customize it to match the real amp like the Salvation modules do.
Caine said:All of the modules can be used in the single channel Egnater and Randall MTS systems but you will only be able to access one of the channels. The Synergy Fender modules have the option of selecting either channel prior to inserting them into your amp, but you cannot switch between the channels with a footswitch like you can with dual channel capable platforms. The advantage of having dual channels is the same as the original Engater dual modules--you can have different gain and volume settings on the two channels and switch between them with a footswitch. The new TD, BMAN and Diezal modules also have separate EQs. Channel 2 of the HBE has more gain.
JKD said:Is a shame this feature didn't make it onto a lot more of the modules but I think as many of them are the same on Ch A/B it's not necessary.
Enter your email address to join:
