need some opinions before I dig in.....fuzzy sounds in rig
Post new topic   Reply to topic    MTS Forum Forum Index -> Egnater / Randall Modular Amps
withmittens
PostPosted: Fri Oct 13, 2017 8:44 am    Post subject: need some opinions before I dig in.....fuzzy sounds in rig Reply with quote
turned on my rig this morning, RT2/50 + RM4.
set at low volume all channels exhibit a fuzzy, fading in & out signal. I fiddled with a few things and determined that raising the volume on both masters at the RT2/50 cleans it up. also, boosting the master volume on each mod does as well but only if the RT2?50 is high enough
does this point to the input tube on the amp needs to be replaced, or the RM4, or somewhere else?
I only have a couple of extra tubes at this point so I'm hoping someone knows right off, having had this happen to them as well.
thanks
RM22, RM4
CrazyNuts' Dirty Sanchez, DuoPlex, Selma, Supra, Twinface, Evil Kitty, CC30, XTC
SG, LP Std., Strat
JKD
PostPosted: Fri Oct 13, 2017 1:51 pm    Post subject: Reply with quote
Poor or dirty connections somewhere....?
Synergy - BE,HBE,SLO,VH4,TDLX,Metro,Plexi, ENGL,OS,BB/BE
JF-Dual Erect
Gigmods - Mark
Hilly-Snorkeler
Egnater -COD, ERECT
Randall - Brahma,Scary, Grail, GTO, SuperV
shortlife
PostPosted: Fri Oct 13, 2017 1:57 pm    Post subject: Reply with quote
I would intermittently get a problem on my RM4 that sounds like what you are describing. It is like a loss of signal that fades in and out.
After some time I discovered the problem is to do with the rear input jack. I switched to the front input and the problem was solved. I have not got around to looking into the cause yet.
withmittens
PostPosted: Sun Oct 22, 2017 8:39 am    Post subject: Reply with quote
thanks for the input. Seems to need a good cleaning.
RM22, RM4
SG, LP Std., Strat
SALVAGED
PostPosted: Mon Oct 23, 2017 5:43 am    Post subject: Reply with quote
My rig had these same symptoms a few years ago. Turned out to be the volume pots in the power amp. Had them replaced & it fixed the problem completely. Could be worth checking.
Jackson KE2
Charvel So-Cal
B.C. Rich JRV 7
Egnater M4
Dualie Mods: JF 1776, JF PRIMATE, JF Rverb, JF Mach-X
GSP1101
Mesa 50/50
Pair of 4X12 cabs w/ WGS speakers (Reapers & Retros in an X-pattern)
Post new topic   Reply to topic    MTS Forum Forum Index -> Egnater / Randall Modular Amps All times are GMT - 6 Hours
