Egnater Mod 50 trouble shooting
Post new topic   Reply to topic    MTS Forum Forum Index -> Egnater / Randall Modular Amps
k9blek
PostPosted: Fri Mar 24, 2017 6:03 am    Post subject: Egnater Mod 50 trouble shooting Reply with quote
I just picked up a Mod 50 in a trade with a dual module. I played it for about 5 minutes or so (on the low power setting) and the sound went out. I switched it to stand by and tried the "high power" side. Nothing. Switch out cables and tried a new cabinet. nothing. I shut it off and then turned it back on after a few minutes to the "high power" section and it worked fine for a few minutes. I switched it to the low power setting and it worked for about 10 seconds before going out again. Tried to switch back to high power. Nothing. Any ideas would be appreciated. Thanks.
RM22/100BP-JF Legato/PlexiTweed/Silverado - Good deals: schlagdog, khingpynn, Nitrous, alowerdeep,rlord1974,BIGKAHUNA,ColdMachine, c2ply,RisingFarce,MattFigOldTimer,JimW427,and Kevrock25, L82theParty,Nitrous,
MarcoR
PostPosted: Sat Mar 25, 2017 6:10 am    Post subject: Reply with quote
The serial loop jacks may need a cleaning. Try a short cable from send to return and see if that stops it from cutting out. If so use something like deoxit and spray on the cable plug and work that in/out of each jack.
Synergy: SYN2, Friedman DS, HBE
Self Modded: Egnater B'Man, SL2X
Amps: VHT 2/50/2, RM50, Landry LS100 G3, Splawn Quick Rod, Marshall 6100LM
Jaded Faith
PostPosted: Mon Mar 27, 2017 5:54 am    Post subject: Reply with quote
FWIW, I have repaired a few of those where the High/Low standby switch has failed. I know Bruce had a bad run of them a few years back. Email me if you need help.
www.jadedfaithmods.com
https://www.facebook.com/JadedFaithMods
Email: info@jadedfaithmods.com
Authorized Service Center for US Music and Egnater
Authorized Reseller for Celestion, Scumback & Mercury Magnetics
View user's profile Send private message Send e-mail Visit poster's website
k9blek
PostPosted: Mon Mar 27, 2017 1:57 pm    Post subject: mod 50 Reply with quote
It actually seems to be working again. I'm not sure what happened but I changed the speaker cable out again. Maybe I didn't have it seated right or something? If it acts up again I'll get in contact Rob. Thanks man !
forensbro
PostPosted: Tue Nov 21, 2017 6:44 am    Post subject: Reply with quote
New to the forum. Has anybody sent their Randall RM50 to Jaded Faith for MM transformer upgrades?
pipedwho
PostPosted: Sat Dec 02, 2017 3:09 pm    Post subject: Reply with quote
This happened on mine too. Symptoms were random intermittent volume drops and cut outs. Sometimes it would work for weeks and then suddenly cut out. Hit the amp and it would be fine again a few more weeks. It got worse over the course of a year, until it happened often enough to diagnose the problem.
As MarcoR said, plugging in a short patch cable in the serial loop send/return fixed it until I was able to properly clean the contacts in the series return jack.
Spencer4hire
PostPosted: Sat Dec 02, 2017 4:54 pm    Post subject: Reply with quote
Yes I have a RM50 head and a RM50 combo that Rob did all of his upgrades to including the transformers. Big improvement over stock other than the extra weight of the heavier iron Laughing
Post new topic   Reply to topic    MTS Forum Forum Index -> Egnater / Randall Modular Amps All times are GMT - 6 Hours
