Synergy VS Egnater : cathode switch
Goto page Previous  1, 2, 3
max44
PostPosted: Fri Dec 08, 2017 5:29 pm    Post subject: Reply with quote
I wonder too, my later dual channel M4 has indeed 2 tubes : one 12AX7 and one 12AT7 ...
Egnater M4 + duals : VX/TD/BMAN/COD/SL2X/MHG
Salvation duals : MashAll+/Salvado
Randall RT2/50 Jaded Faith Foglifted +NFB
Home crafted guitars
MarcoR
PostPosted: Sat Dec 09, 2017 9:20 am    Post subject: Reply with quote
I believe V2 is the output buffer on the dual M4. Synergy probably didn't go for a tube driven buffer to save some space?
Synergy: SYN2, Friedman DS, HBE
Self Modded: Egnater B'Man, SL2X
Amps: VHT 2/50/2, RM50, Landry LS100 G3, Splawn Quick Rod, Marshall 6100LM
max44
PostPosted: Sat Dec 09, 2017 11:07 am    Post subject: Reply with quote
Ok,
And do you know which one is V1 ?
Top/right tube emplacement is labelled 12AT7
Bottom/left tube emplacement is labelled 12AX7
But actually both tubes were the same (12AX7) and the same model as in all of my modules (stock and mods) : Sovtek 7025 / 12AX7WA
I tried different tubes in both emplacements :
- Electro-Harmonix 12AX7EH : they give more gain overall ... good for hi-gain modules
- TAD 12AX7 A-C : I like these as they seem to "open" every module, and specially the low/mid gain modules for blues sounds (T/D - COD ...)
maxxstock
PostPosted: Sat Dec 09, 2017 12:11 pm    Post subject: Reply with quote
Bottom/left tube emplacement is labelled 12AX7 is V1
12AT7- is buffer
The aim and final end of all music should be none other than the glory of God and the refreshment of the soul.
"Johann Sebastian Bach"
djdayson
PostPosted: Mon Dec 25, 2017 5:15 pm    Post subject: Reply with quote
Thanks Rob!
Any chance you know what the new Synergy Sag control is doing (browning out B+, or?)?
Page 3 of 3
