HBE Squealing Feedback
TubeMan5150
PostPosted: Sat Jan 13, 2018 1:37 pm    Post subject: HBE Squealing Feedback Reply with quote
My new HBE module is unusable with the gain past noon. I get a ton of squealing feedback then. In comparison I also have the SLO and BE and both those modules are quiet even with gain at 3 o'clock.
I replaced the pre-amp tubes in the HBE...no change. Probably needs to be sent back to Synergy.
Anyone else experience this with a high gain module?
Randall Jaded Faith RM100, Egnater Tourmaster 4100, Egnater Armageddon
Jaded Faith Mods: D-Zilla, J-Plex, VX30
Salvation Mods: Mamba SE
Synergy: BE, HBE, SLO
gtr31
PostPosted: Sun Jan 14, 2018 9:55 am    Post subject: Reply with quote
does it get worse turning any of the tone controls up
I know a few guys had an issue with DZL mod , and it was a ground on the mid pot
ricky
PostPosted: Tue Jan 16, 2018 12:06 pm    Post subject: Reply with quote
I have a single mod form Salvation and like another mod from JF that doesn't just seat right and squeals when I turn up the gain or turn on the high gain switch. I press on the faceplate and it goes away. Try that and if that is the case I have a quick fix for you.
TubeMan5150
PostPosted: Wed Jan 17, 2018 4:38 pm    Post subject: Reply with quote
OK I take back blaming the HBE module. There is nothing wrong with it.
After more detailed troubleshooting and the problem getting more consistent (less intermittent), worse, and affecting all the modules in the amp now it's the FX loop. After unplugging the loop, problem gone. Probably the FX loop buffer tube. Swapping in a new tube is next on my list.
On another note I did get quick reply from Boutique Amps Distribution tech support. So that's a good thing.
