SYN 5050
Post new topic   Reply to topic    MTS Forum Forum Index -> Synergy Amps & Modules
wurs
PostPosted: Fri Feb 02, 2018 12:47 pm    Post subject: SYN 5050 Reply with quote
I'm probably not going to run this is stereo but I want to know if I can run this mono at 50 watts? (IE just use channel A.) From what I read in the manual I think you can but I want to make sure.
wurs
PostPosted: Fri Feb 02, 2018 12:51 pm    Post subject: Re: SYN 5050 Reply with quote
OR use Channel A for the SYN2 in mono 50 watts and say have the AxeFx2 running into Channel B Mono 50 watts?
tnjazz
PostPosted: Fri Feb 02, 2018 2:14 pm    Post subject: Reply with quote
I'm kind of trying to figure this out myself because the manual isn't very clear.
If the amp is in stereo mode, does it by default output mono to both channels unless something is plugged into the second input or into a stereo return?
Seems like a 3 way slider with stereo/mono/bridged would have taken care of the confusion.
wurs
PostPosted: Fri Feb 02, 2018 3:26 pm    Post subject: Reply with quote
I agree. The manual is confusing.
wurs
PostPosted: Fri Feb 02, 2018 3:27 pm    Post subject: Reply with quote
The manual says that you don't have to have channel B plugged into a speaker (or Load) if you are not using it. So I assume you can use A & B independently.
But is someone can clear this up that would be great.
webrthomson
PostPosted: Fri Feb 02, 2018 4:38 pm    Post subject: Reply with quote
I would assume that is if you are running the amp in mono. If you are running the amp in stereo I would always have a load on both outputs, unless the guys at Synergy expressly confirm there is an internal load in the amp.
teofilrocks
PostPosted: Fri Feb 02, 2018 6:18 pm    Post subject: Reply with quote
If you have the 5050 in stereo mode, but are only using input A, keep channel B on standby. No speaker load needed on the B side when doing this.
tnjazz
PostPosted: Fri Feb 02, 2018 6:56 pm    Post subject: Reply with quote
Then the question is - does the amp actually do parallel mono somehow (at 50w per side) or is the only mono option bridged mode?
teofilrocks
PostPosted: Fri Feb 02, 2018 8:53 pm    Post subject: Reply with quote
By “parallel mono” do you mean using input A only but using speaker outputs A and B?
tnjazz
PostPosted: Sat Feb 03, 2018 8:33 am    Post subject: Reply with quote
Exactly. I want individual level control per channel. For instance, a nice loud cab right behind me and a much quieter cab on the other side of the stage for a very particular bass player, lol
j4q0
PostPosted: Sat Feb 03, 2018 12:37 pm    Post subject: Reply with quote
The amp is not dual mono, is only mono bridged.
The manual says: (rear panel page)
#3. "If selecting MONO, you must connect to Channel A input only..."
#10. "When using the amp in the MONO BRIDGE mode, use only the CHANNEL A/MONO input and the CHANNEL A SPEAKER OUTPUTS ... The CHANNEL B IMPEDANCE switch is disconnected in the MONO BRIDGE mode"
#11. "...In MONO BRIDGE, the CHANNEL B input is disconnected... THE CHANNEL B input and CHANNEL B speaker outputs are not used in the MONO BRIDGE mode."
If you want to use the same mono signal and send it to 2 different cabs and have independent volume control for each, you need the amp in stereo mode and connect a "Y" cable between your mono output (from FX or preamp) and both inputs on the SYN5050.
Good deals: http://goo.gl/lSJJVT
Post new topic   Reply to topic    MTS Forum Forum Index -> Synergy Amps & Modules All times are GMT - 6 Hours
