SYN-5050 and SYN-2
Post new topic   Reply to topic    MTS Forum Forum Index -> Synergy Amps & Modules
Badjambanana
PostPosted: Sat Jan 27, 2018 10:51 pm    Post subject: SYN-5050 and SYN-2 Reply with quote
Anyone know to hook up an SYN-2 to an SYN-5050?
tnjazz
PostPosted: Sun Jan 28, 2018 7:17 am    Post subject: Reply with quote
Line out of the SYN-2 to line in on the power amp I would think?
webrthomson
PostPosted: Sun Jan 28, 2018 8:43 am    Post subject: Reply with quote
Two ways as follows:
Stereo as 50/50 watts per side:
The Syn2 Left/Right outputs - into the SYN50/50 A / B ins (far right on the power amp) - then A / B outs (use the left ones first) into 2x50 watt rated cabs.
Mono - 100 watt
The Syn2 Left output - into the SYN50/50 A in (far right on the power amp) - then A out (use the left one first) into a 100 watt rated cab.
NB - if you are running in mono MAKE SURE THE SYN50/50 IS SET TO MONO before you turn it on!
Steomixs
PostPosted: Sun Feb 04, 2018 10:12 pm    Post subject: Reply with quote
I can find information to help find a solution. And support for you
Post new topic   Reply to topic    MTS Forum Forum Index -> Synergy Amps & Modules All times are GMT - 6 Hours
