What Power Amp For Syn2
Area for the Synergy line of amps and modules
sherpa_man
Post by sherpa_man » Thu Feb 08, 2018 9:25 am
Hi,
I have a synergy 2 unit and i am looking for a power amp. Problem i have is, i don't really want to drop £1200 on the synergy 50/50 as i am only using this for a small bedroom setup. I can buy a used Mesa 2:100 for £500 over here in the uk.
What are your thoughts?
Many thanks
JKD
Post by JKD » Thu Feb 08, 2018 11:15 am
Used Mesa 2:90 or VHT...I seem to recall Carvin doing a great one at one point too..
Synergy - HBE,SLO,VH4,TDLX,Plexi, ENGL,OS,BB/BE
Salvation-Deadplate, Spawn, MarkUS, Dual Salvado+JJ Dirt+Terrier
JF-Dual Erect
Gigmods - Mark
Hilly-Snorkeler
Egnater -COD, ERECT
Randall - Brahma,Scary, Grail, GTO, SuperV
keg8605
Post by keg8605 » Thu Feb 08, 2018 3:54 pm
If you don't need stereo the Fryette Power Station works. Other options
Mooer Tube Engine 20 watts mono coming out in april cheap
VHT/Fryette 2/50/2 or 2/90/2
Randal RT 2 50 cool because one side can have el34's and 6L6 on the other.
Mesa 2/90 2:50 or 20/20
Peavey makes some cheap ones out there
Carvin TS 100 is affordable too
Marshall has some as well.
Plenty of options. Budget and needs will narrow it down for you.
Synergy Syn2 with T/DLX and SLO modules
AXE FX XL for all fx and cab ir's as well.
withmittens
Post by withmittens » Thu Feb 08, 2018 9:03 pm
That Mooer looks cool. I bet it will be a modders amp
RM22, RM4
CrazyNuts' Dirty Sanchez, DuoPlex, Selma, Supra, Twinface, Evil Kitty, CC30, XTC
SG, LP Std., Strat
Ripleyripley
Post by Ripleyripley » Sat Feb 10, 2018 2:44 pm
I reached-out to Fryette to see if the PS-2 I own would be a good alternative to the 50/50. They mentioned a lot of the proving-out of the Synergy Testing was done with the PS-2. It sounds great.
blacknoize
Post by blacknoize » Tue Feb 27, 2018 11:14 am
I used a Randall RT2/50. Great amps when you can find them.
chrismilne
Post by chrismilne » Tue Feb 27, 2018 12:01 pm
I'm using a Power Station as well...has the added benefit of being able to record silently, still pushing Power Tubes and recording direct to DAW using IR's.
I haven't opened it up yet to hear how it sounds, i've mostly only been running on a Bogner 1x12 or direct at house volume. I also have a Peavey Classic 50/50 for stereo use when i get a chance to hook it all up in stereo.
Synergy: Syn-2, SLO, Metroplex
Randall: JTM, Clean, Blackface
Egnater: EG2
Strymon Flint and Mobius, TC Triple Delay, JHS Andy Timmons, Kemper, Ventris, Koko Boost, Carl Martin AT Compressor, Proanalog MKIV Fuzz, Ibanez TS9dx
