Dead rt 2/50
Discussion area for Jaded Faith custom modules
Moderator: Jaded Faith
guitarmanscott65
Dead rt 2/50
Post by guitarmanscott65 » Sat Dec 16, 2017 3:37 pm
I will probably have to send it to Rob, but I feel I should try this one thing first, if anyone is willing to help. I have no juice coming out of the PT. I noticed a sticker on the tranny that says it has a resettable fuse. I'm assuming wrapped in the PT as I don't see it externally. Does anyone know the value and where to get a replacement? I'd rather have one on hand before I start tearing into the trans. I realize this is not the best place for this topic, but I have tried in another place and got no response. Maybe I'm doing something wrong here but all you guys have always been a great help to me. Any information would be greatly appreciated. Down and out in Posmtown.
you can tuna piano but you can't tune a fish
Jaded Faith
Post by Jaded Faith » Wed Dec 20, 2017 8:56 am
It's a thermal fuse that self-resets. You don't manually do it. If you are not seeing anything on the secondary taps it's likely time for replacement.
www.jadedfaithmods.com
https://www.facebook.com/JadedFaithMods
Email: info@jadedfaithmods.com
Authorized Service Center for US Music and Egnater
Authorized Reseller for Celestion, Scumback & Mercury Magnetics
guitarmanscott65
Rt 2/50
Post by guitarmanscott65 » Wed Dec 20, 2017 12:10 pm
Thanks man. Can I purchase a new fuse from JF?
Jaded Faith
Re: Rt 2/50
Post by Jaded Faith » Sat Dec 23, 2017 8:08 am
guitarmanscott65 wrote:Thanks man. Can I purchase a new fuse from JF?
I'm not sure which fuse you are talking about? The ones in the amp are commonly available. If you meant the thermal fuse in the PT, it's not replaceable. You have to replace the entire PT. If it's no longer resetting, the PT burned out. That also said, it's probably a good idea to get the unit repaired because something probably failed and took out the PT. They nearly never fail on their own accord.
guitarmanscott65
dead rt 2/50
Post by guitarmanscott65 » Mon Feb 12, 2018 12:45 am
would a power trans out of a rm100 work ?
Jaded Faith
Re: dead rt 2/50
Post by Jaded Faith » Wed Feb 14, 2018 8:24 am
guitarmanscott65 wrote:would a power trans out of a rm100 work ?
No. The transformers in the RT 2/50 were made by Heyboer and closer to the RM50, but not the same. I'd actually have to do some legwork on that if the repair was here, as I've never looked into a replacement for those.
nickerz
Post by nickerz » Mon Aug 27, 2018 6:52 pm
Have you found the RT2/50 to be generally reliable?
