Salvation AntiSaint vs MarkUS
Post new topic   Reply to topic    MTS Forum Forum Index -> Modules
JKD
PostPosted: Fri Mar 09, 2018 2:02 pm    Post subject: Salvation AntiSaint vs MarkUS Reply with quote
Question:
If you had both of these, which would you sell...and why?
Synergy - BE,HBE,DS,SLO,VH4,TDLX,Metro,Plexi
JF-Dual MachX+ERect+MarkX
Gigmods - Mark
Hilly-Snorkeler
Egnater -COD
Randall - Brahma,Scary, Grail, GTO, SuperV
PostPosted: Fri Mar 09, 2018 2:56 pm    Post subject: Reply with quote
My MarkUS was the first to add the Recto voicing instead of the flat EQ option....I believe that is what the AntiSaint has on it....If so, I much prefer the MarkUS with Recto voicing (Though it is special request)....
The reason people like to have the flat voicing is mainly for cleans (which I don't use MarkUS for) so I like the toggle having V-Scooped and Recto voicing as Antisaint....
JKD
PostPosted: Fri Mar 09, 2018 5:02 pm    Post subject: Reply with quote
What does the regular EQ toggle do on the MarkUS?
I honestly don't remember if my ASVNT has an EQ toggle...,,
Actually both have a Shape and Shift switch...plus ASVNT has DEEP.
Gigmods - Mark
Hilly-Snorkeler
Egnater -COD
shortlife
PostPosted: Fri Mar 09, 2018 10:22 pm    Post subject: Reply with quote
They both in my Rm4 right now.
I am using the MarkUs for Hi gain and the Antisaint for the clean.
I find that the deep switch on the Antisaint gives it a better clean,
and I use the V eq on both and don't plan to sell either of them. Very Happy
JKD
PostPosted: Sat Mar 10, 2018 4:16 pm    Post subject: Reply with quote
hahhah! Not helping, lol! \m/
Gigmods - Mark
Hilly-Snorkeler
Egnater -COD
aside
PostPosted: Sun Apr 08, 2018 3:12 am    Post subject: Reply with quote
The MarkUs seems to get good reviews - can it do that tight, dry Hetfield thang?
shortlife
PostPosted: Sun Apr 08, 2018 6:40 am    Post subject: Reply with quote
It can do Master Of Puppets for sure, I use it with a Tube screamer in front and it nails that tone. It is very tight.
aside
PostPosted: Mon Apr 09, 2018 6:48 am    Post subject: Reply with quote
How are you using the TS - with the gain right down?
Salvation: JJDirt, Camerock, MarkUS, Humble OD
Jaded Faith: Mark X
Synergy: SLO
shortlife
PostPosted: Mon Apr 09, 2018 12:24 pm    Post subject: Reply with quote
Yes, Gain all the way down and volume normally three quarters of the way up.
You can get a lot of gain and compression sculpting going using Gain and Lead Drive along with the volume control on a Drive pedal.
buriedorburned
PostPosted: Mon Apr 09, 2018 2:01 pm    Post subject: Reply with quote
Iím playing a Mesa Mark V35, and the tone on Mk IIC+ and IV modes unboosted are hands down some of the best heavy tones Iíve ever played.
The IIC+ is Metallica Master / AJFA all day long and the Mk IV IS Lamb of God - New American Gospel. Iím blown away.
I think Iím going for a MarkUs next to see how it stacks up in my Syn-1 against the V35.
aside
PostPosted: Sun May 06, 2018 3:12 pm    Post subject: Reply with quote
So I got a MarkUs and I'm not really digging it. Not sure if it's a taste thing or the unit actually has a fault (it's well used).
How do you guys set yours up? I played with it for quite a while but it doesn't sound tight and heavy, more fizzy and loose.
I replaced the valves, and tried with two different amps.
Jaded Faith: Mark X
Synergy: SLO
JKD
PostPosted: Sun May 06, 2018 10:58 pm    Post subject: Reply with quote
I assume this is how I generally play mine.....though has been out of my amp a while so maybe the pots moved....I think it's easy to over dial the gain and fizz may be a variant of the speaker/power amp tubes too...but to me it sounds like it gets that that classic MESA metal sound....a la Petrucci or Metallica
http://i691.photobucket.com/albums/vv279/jkdsteve2/IMG_0967_zpst7rzhdig.jpg
Gigmods - Mark
Hilly-Snorkeler
Egnater -COD
aside
PostPosted: Mon May 07, 2018 3:28 am    Post subject: Reply with quote
Ok thanks mate. Pretty sure there's something not right with this thing. Really lack in lows and low mids, weird attack and fizz.
Does yours offer any clean sound at all? I can't get anything close to a decent clean from this thing.
Jaded Faith: Mark X
Synergy: SLO
JKD
PostPosted: Mon May 07, 2018 8:49 am    Post subject: Reply with quote
Never tried...lol. I'll have a go later.
It's sounding like you maybe have a poor solder joint or perhaps a bad pot.
Gigmods - Mark
Hilly-Snorkeler
Egnater -COD
aside
PostPosted: Sat May 12, 2018 6:02 pm    Post subject: Reply with quote
Fixed - a cap had been knocked and a leg broke off, easy fix in the end.
All the values on the caps have been blacked out which makes repairs that little bit harder - better than goop all over it I guess Shocked
Jaded Faith: Mark X
Synergy: SLO
Post new topic   Reply to topic    MTS Forum Forum Index -> Modules All times are GMT - 6 Hours
