RM20 measurements
Post new topic   Reply to topic    MTS Forum Forum Index -> Egnater / Randall Modular Amps
Spencer4hire
PostPosted: Tue Mar 27, 2018 12:10 am    Post subject: RM20 measurements Reply with quote
Could someone who owns a RM20 combo please tell me the height of the amp. Going to get a cover for my one off RM22 combo and want to see if it is the same height. Thanks in advance.
warmachine67
PostPosted: Tue Mar 27, 2018 12:09 pm    Post subject: Reply with quote
Rm20 combo: 19.5" tall by 17.5" wide by 11" deep
Spencer4hire
PostPosted: Tue Mar 27, 2018 12:44 pm    Post subject: Reply with quote
Thank you so much!
warmachine67
PostPosted: Tue Mar 27, 2018 1:02 pm    Post subject: Reply with quote
Is this the rm22 combo prototype that I read about somewhere or did you add a cabinet to an rm22 head?
Spencer4hire
PostPosted: Tue Mar 27, 2018 5:32 pm    Post subject: Reply with quote
It was a the prototype made by Randall. I have since sent it to Rob@ Jaded Faith Mods and had the full treatment done to it. Mercury Magnetics transformers and choke,Foglifter plus,and a master volume pot. What a total difference.
warmachine67
PostPosted: Tue Mar 27, 2018 8:20 pm    Post subject: Reply with quote
I always wondered where that amp ended up. Glad you had it upgraded properly. I had Rob do the same to my rm22 and rm20. Worth every penny.
I doubt you will ever part with that one, but I'll take it if you do Wink.
Spencer4hire
PostPosted: Tue Mar 27, 2018 8:29 pm    Post subject: Reply with quote
Need to have Rob do the upgrades on my RM20 head.
If I ever decide to let the RM22 combo go I will give you first shot at it.
shortlife
PostPosted: Wed Mar 28, 2018 12:07 am    Post subject: Reply with quote
Try using your modded rm20/22 as Slave/Reamper.
I am using mine with a Shur reactive load and it sounds fantastic.
It works like a Fryette Powerstation, I love my Powerstation 2
but this set up has basically retired it.
Signal chain - Amp - Loadbox - line out into RM20/22 effects return.
Next find your preferred balance between the DI level from your loadbox line out and the Master volume on the RM20/22 and you will have tonal bliss at any volume.
Just make sure to turn down/off any tone controls on the main amp's power section and use the power amp Presence and Depth on the RM20/22 instead.
I have tried this with a bunch of amp's and it sound killer with all of them.
Post new topic   Reply to topic    MTS Forum Forum Index -> Egnater / Randall Modular Amps All times are GMT - 6 Hours
