Hi all,
I need to replace some mini pots (gain, volume) on my Egnater dual modules;
it seems like they are Alpha 1 Mohm Logarithmic 13mm diameter body, i already checked Mouser and Digikeys but haven't found nothing, only standard 16mm pots for single modules.
Some of you guys know where I can find them, if possible, in Europe?
Also, there seems to be two different printed codes at the back (one is 7N4, the other is 6E1), though the value is the same for both?
Thanks in advance for your help,
cheers
cheers
