RM20 issue
ricky
PostPosted: Wed May 30, 2018 12:49 pm    Post subject: RM20 issue Reply with quote
I am having an issue with my RM20. So if you own one you know that it has a FS where you can set a boost and toggle between loud and real loud. With the boost engaged, it "blats out." The other channel is fine. Once it is warmed up, usually about ten minutes it no longer does the blatty thing. I am guessing that there is a tube that is causing this but now sure which one to go for. Is there an input tube that could cause this and where is it located so that I can pull it in order to try a new tube?
Thanks
rick
ricky
PostPosted: Sat Jun 02, 2018 9:35 am    Post subject: Reply with quote
bump
PostPosted: Sat Jun 02, 2018 9:55 am    Post subject: Reply with quote
The preamp tube closes to the input jack is your input tube....Smile. good luck!
