RM 1250 + duals midi switching
Hello MTS users,
I just got (lucky to get) a Randall RM 1250,
On top of that I use my 12 dual modules in it, so it is a perfect world !
The original footswitch works fine but has only 3 buttons, so each button switches 8 channels : 1-8 / 9-16 / 17- 24 (not useable live ...)
I have a G Lab GSC2 midi footswitch that I try to configure with the RM1250 and the duals, without success yet : if anyone can help that would be great
Thanks, Max
Thanks, Max
Egnater M4
Randall RT2/50 & RM1250
Dual modules
Home crafted guitars
Dual modules
Thanks guys,
I guess it was designed only for studio work then ...
I can live with it, just have to be super fast with my feet to change channels if I wish to use it live !
Matt fig :Yeah it is quite a beast and I would add : if amps were engines this would be The V12 of all amps
Jayda : I still have your fog lifted RT2/50 and it still sounds awesome
Max
Max
Egnater M4
Dual modules
Dual modules
Jayda : Yes it is a great amp ... even in stock form since it has Heyboers transformers (as explained by Rob from Jaded Faith)
The Foglift + NFB pot add even more articulation !
On the other hand the RM1250 has chinese transformers (made in Taiwan actually) and I can clearly tell the sound is different and feels less powerful ...
I'm actually talking with Rob to improve the RM1250 in a simple way : Foglift and things like that, as changing the transformers on this beast would be too much of a hassle (Rob has done it in the past but it was a pain of a job apparently)
Back to topic : I have talked to Galao (who provides the dual channel modification midi kit) and he told me the RM1250 has midi connections, but is not programmable and only reacts to CC# (Continuous Control messages) so it means it can be controlled, but only with a programmable Midi footswitch (i.e. Roland FC 300, Behringer FC1010 for instance)
I have asked GLab to help me out with this, expecting their answer and will let you know
Max
Max
Egnater M4
Dual modules
Dual modules
- RM100
If you do have any success with cracking the midi code on the 1250, please report it here.
As for mods, just sending Rob the board and having a normal foglifter mod will be the biggest bang for your buck when shipping is considered. I think the stock presence board on a 1250 is one of the biggest reasons they don’t sound as good.
Problem solved :
Thanks to Galao who pushed me going through my GLab Gsc2 manual - concerning the CC# setup - I finally manage to set it up with the RM1250
So for those who care : your midi pedalboard / footswitch has to be programmable (able to send CC messages), and has to send messages on midi 1 channel only (RM1250 is setup on midi 1 channel)
For single modules the RM1250 will recognize the following CC# :
(as listed in the RM1250 manual)
- module 1 : CC# 1
- module 2 : CC# 6
- module 3 : CC# 7
- module 4 : CC# 8
- module 5 : CC# 9
- module 6 : CC# 14
- module 7 : CC# 15
- module 8 : CC# 16
- module 9 : CC# 17
- module 10 : CC# 22
- module 11 : CC# 23
- module 12 : CC# 24
For dual modules the RM1250 will recognize the following CC# :
- module 1 channel A : CC# 5
- module 1 channel B : CC# 1
- module 2 channel A : CC# 6
- module 2 channel B : CC# 2
- module 3 channel A : CC# 7
- module 3 channel B : CC# 3
- module 4 channel A : CC# 8
- module 4 channel B : CC# 4
- module 5 channel A : CC# 13
- module 5 channel B : CC# 9
- module 6 channel A : CC# 14
- module 6 channel B : CC# 10
- module 7 channel A : CC# 15
- module 7 channel B : CC# 11
- module 8 channel A : CC# 16
- module 8 channel B : CC# 12
- module 9 channel A : CC# 21
- module 9 channel B : CC# 17
- module 10 channel A : CC# 22
- module 10 channel B : CC# 18
- module 11 channel A : CC# 23
- module 11 channel B : CC# 19
- module 12 channel A : CC# 24
- module 12 channel B : CC# 20
Strangely enough single modules' CC# don't always correspond with channel A's dual modules' CC# ... So I guess if one changes from single to duals, one will recall channel A's dual modules for the same preset only in slots 2 - 3 - 4 - 6 - 7 - 8 - 10 - 11 - 12
(and channel B's dual modules for the same preset in slots 1 - 5 - 9)
Weird ! and I hope I made myself understandable ...
(I only own dual modules, no singles, so I could not compare : this is only a guess ...)
Have fun !
Max
- module 1 : CC# 1
- module 2 : CC# 6
- module 3 : CC# 7
- module 4 : CC# 8
- module 5 : CC# 9
- module 6 : CC# 14
- module 7 : CC# 15
- module 8 : CC# 16
- module 9 : CC# 17
Have fun !
Max
Egnater M4
Dual modules
Dual modules
- RM100
Warmachine67 : You're welcome !
I only own dual modules, that's why I bought this RM1250 cause I knew it would play and switch both channels ... the only issue was that midi setting : now we know this beast can be controlled conveniently (i.e live !) with an adequate midi footswitch and this is great news
Quote : " As for mods, just sending Rob the board and having a normal foglifter mod will be the biggest bang for your buck when shipping is considered. I think the stock presence board on a 1250 is one of the biggest reasons they don’t sound as good "
I will definitely think about this ... thanks
Max
Max
Egnater M4
Dual modules
Dual modules
- RM100
Not trying to hijack the topic, but since midi Jedi masters are participating:), any idea if a Rocktron Midimate could be used with the 1250 for dual CC access?
I just don’t have enough midi knowledge to read the manual online and know if it will work. The midimate is cheaper than the Roland and has a smaller size without the two cc pedals, that’s why I’m wondering.
As a MIDI-Jedi I can confirm that the Midimate is also fine for this purpose. It can send programmable CC-messages and can be phantom powered over a seven-pin-MIDI-cable, which is a plus. I just don´t like to read manuals for other people to give them step-by-step-instructions except they have questions about my products.
DUAL CHANNEL MODS
https://yuneo.de
https://yuneo.de
- RM100
