Thanks man. I will be using humbuckers. I would like the Bman level of clean if that can be acheived with this? You've had the Egnater Bman but not the Synergy right?
The Voxless could be the way to go as the Bmans aren't cropping up on Reverb anymore.
I would say the clean on this is between the BMan and the AC. Probably a little more towards the AC overall. The BMan modules I’ve had could do very clean tones in channel A in particular. The JF isn’t as pristine, but of course it’s not intended to be a Fender type clean in the first place.
