What are you using to eliminate hum/noise form your Syn rig?
LuxxtoneBoy
Post by LuxxtoneBoy » Tue Dec 04, 2018 8:18 pm
I’m getting some hum out of my Synergy rig (Syn 50/50 and 2 Syn 2’s) and would like to add a noise gate/noise suppresor to the rig. What are you guys using with your rigs?
webrthomson
Re: What are you using to eliminate hum/noise form your Syn
Post by webrthomson » Wed Dec 05, 2018 2:19 am
LuxxtoneBoy wrote:I’m getting some hum out of my Synergy rig (Syn 50/50 and 2 Syn 2’s) and would like to add a noise gate/noise suppresor to the rig. What are you guys using with your rigs?
Fortin Zuul - easily the best noise gate that I've ever used, better even than rack mount stuff.
Not cheap though!
tnjazz
Post by tnjazz » Wed Dec 05, 2018 6:21 am
I use my FX8 front noise gate set between 50 and 60 depending on the guitar, and a gate block in the loop for drive channels (gate off for clean channels)
Well it’s been fun...!
shortlife
Post by shortlife » Thu Dec 06, 2018 12:46 pm
You should not be using a Gate to bury the noise before getting rid of as much noise as possible via grounding and protection from electrical interference.
I use a fairly pricey Furman Power Conditioner and a Radial SB-6 Isolator to cure most of the problems and then a gate between the Preamp and Power Amp.
I own a TC Electronic Sentry, a Fractal Fx8 and a Fortin Noise Gate.
The Fortin gate using the key input is by far the best Noise Gate I have used.
JKD
Post by JKD » Thu Dec 06, 2018 2:06 pm
ISP Decimator Pedal...it rules, though I have to say there's less hum/noise with Synergy than with my Randall stuff.
Synergy - HBE,SLO,VH4,TDLX,Plexi, ENGL,OS,BB/BE
JF-Dual Erect
Gigmods - Mark
Hilly-Snorkeler
Egnater -COD, ERECT
Randall - Brahma,Scary, Grail, GTO, SuperV
RipperShred
Post by RipperShred » Thu Dec 27, 2018 3:17 pm
4-cable'd with a helix rack. Gated on the input stage, then on the back end too if need be. then all the FX I could ever want as well. :D
danielmorrison
Electro-Harmonics Hum Debugger
Post by danielmorrison » Sun Jan 20, 2019 3:35 pm
The EHX Hum Debugger worked for me. It's not a gate so it will just eliminate the hum.
ChrisB
Post by ChrisB » Wed Jan 30, 2019 7:21 pm
I picked up the Zuul after reading this post and watching some YT videos, what a great pedal!
LuxxtoneBoy
Zuul
Post by LuxxtoneBoy » Thu Jan 31, 2019 5:40 pm
Where do you place the pedal in your rig?
ChrisB
Post by ChrisB » Fri Feb 01, 2019 6:09 am
It's the first pedal in the loop before the reverb and delay, I am also using the key input in front of my SYN50 with a boss tuner. What sold me was the Ola Englund video, it's worth the $$$
Kingpapavega
Post by Kingpapavega » Fri Feb 01, 2019 11:30 am
I need to check that out. I still have a little bit of background noise I need to eliminate.
