Syn 2 + Syn 2
werdna
PostPosted: Tue Nov 27, 2018 11:19 pm    Post subject: Syn 2 + Syn 2 Reply with quote
I want to run four Syn modules at a time, and have them programmed so that I am able to midi footswitch from one channel to each of the other seven and back. Could I do it with two Syn 2s?
RM4, RT2, seven old school Randall modules with three being modded, Marshall plexi with Jose circuit.
tnjazz
PostPosted: Wed Nov 28, 2018 6:27 am    Post subject: Reply with quote
yes, but not with the Synergy footswitch. It will require a different MIDI controller to access all 8 without reprogramming. I use a Fractal FX8 to do this with my setup.
Just need one more module...
RipperShred
PostPosted: Thu Dec 27, 2018 3:19 pm    Post subject: Re: Syn 2 + Syn 2 Reply with quote
This is what I'm ultimate after too; 8 channels of awesomeness.
Kriig
PostPosted: Wed Mar 13, 2019 2:34 am    Post subject: Reply with quote
I'm hoping for a SYN4 in the future, but i doubt it will come.
TubeMan5150
PostPosted: Wed Mar 13, 2019 5:44 pm    Post subject: Reply with quote
I'm running 3 SYN-2's for 12 channels of awesomeness.
I don't have a problem and can stop anytime...
Randall Jaded Faith RM100, Egnater Tourmaster 4100, Egnater Armageddon
Synergy: TDLX, BMAN, DS, BE, HBE, SLO, VH4
Kriig
PostPosted: Thu Mar 21, 2019 11:05 am    Post subject: Reply with quote
How do you hook them up?
One through the other?
RipperShred
PostPosted: Thu Mar 21, 2019 12:38 pm    Post subject: Reply with quote
I run several preamps in the loops of a Helix Rack, and that makes switching the channels (and different preamps) super convenient and easy. Smile
TubeMan5150
PostPosted: Thu Mar 21, 2019 5:38 pm    Post subject: Reply with quote
I've got them hooked up like discussed in the Syn-2 manual.
Connecting Multiple SYN2s
Follow the steps below to combine 2 or more SYN2 units. In this connection scheme the first SYN2 in the signal chain is called the “Master” and the second SYN2 is the called the “Slave”.
- Connect your instrument to the Input of the Master unit.
- Run a cable from the "TO AMP IN" of the Master unit to the "INST. IN" on the rear panel of the Slave unit.
- Connect the main output L/MONO of the Slave unit to the "FROM AMP FX SEND" of the Master unit.
- Use the MAIN OUT(s) or the DI output(s) of the MASTER unit to connect to your power amp / monitors.
- Program the Slave with the Master in Bypass Mode.
Note - When using the input on the front panel, the "INST IN" on the back panel is disengaged.
The same procedure is recommended for adding a third, fourth etc. unit to the system
For most systems, it’s recommended that you set your SYN2s to the same MIDI channel. You can follow the
programming instructions above, repeating the steps for each SYN2. When you want to access the second SYN2, make sure that the first SYN2 is set to bypass.
Kriig
PostPosted: Fri Mar 22, 2019 4:07 pm    Post subject: Reply with quote
Thanks guys Very Happy
ricky
PostPosted: Sat Mar 23, 2019 12:33 pm    Post subject: Reply with quote
Rippershred. Are you putting each SYN2 in a separate loop in the Helix?
RipperShred
PostPosted: Mon Mar 25, 2019 11:19 am    Post subject: Reply with quote
Yeah dude, 4 loops = 4 different preamp units, and in this case syn2 units. I got a syn2 in one loop, an e570 in another, a gp3 in another. Can run several simultaneously, switch channels and/or preamps in the snapshots/scenes with a click of a footswitch and go from clean/chorus/reverb to crunch with a boost to a boosted lead with phaser and delay. It's the shiz-nit. Smile
ricky
PostPosted: Mon Mar 25, 2019 12:10 pm    Post subject: Reply with quote
I use the SYN 2 in one of my Helix loops and then into an M50 head. The Helix is pretty amazing. So basically I have four SYN/JF mods (meaning 8 channels) and I switch between them with the Helix which switches FX if I want.
BTW, what is the GP3?
RipperShred
PostPosted: Mon Mar 25, 2019 1:58 pm    Post subject: Reply with quote
Fryette/vht valvulator. Very Happy
