SYN50 head "auto sensing" question...
turkeyjerky1991
Does anyone know if the auto sensing feature of the Synergy amps works properly with the Randall and Egnater MTS modules?
The SYN50 website says: "AUTO SENSING The SYN50 features a patent pending technology that “senses” which preamp modules are being installed into it. Once a module is detected, the SYN50 adjusts the cathode biasing circuitry on the built in 12AX7 tube, to best match the original amplifier channel design on which it’s based"
It doesn't.
The feature is new technology that only works with the Synergy modules.
I guess that the old modules could be modded to be able to use this feature with them?
If there was a way to do it, i'm sure Rob and Antonin would have been offering it by now
The syn 1 and 2 have the auto sensing, as well as the combos. The 5050 does not because it is a pure power amp.
Rob with jaded faith does have a mod to the Randall amps that is similar to the auto sensing. However, it is a 3 way switch on front that must be manually selected.
