Ok... all knobs you put on 12 hours and eq. set in V formation but depending on what cab you use you start from zero or you add some bottom... I have it's original 125 cab and I start from zero 'cause my 15" already gives enough bottom end... sometimes too much. Attack you set at loose... level is up to you... but please do not push gain knobs more than 5... no need at all....EvileOL said:Hey all, just wondering if anyone had any info/advice on how to get the best out of your Randall V2 head if you were to play Heavy Metal/Thrash.
