RT2 - what tubes can it handle...
davenit
Hi all. In the manual it states some of the possibilities but what all power tubes can it accept?
It says EL34, 6L6, 5881, 6CA7 and 6550's. Anything else?
Dave
It might be able to handle KT77s an 88s too. Those who are into valves in a big way might tell you which ones are pentodes (EL-34 family in a sense) and which are triodes (6L6 family). Then, as long as the amp technically can handle the current draw and the bias setting will allow the valve to be used you can put in what ever you like.
