RT-250 Question
rickgk
Hi Guys,
I was just wondering when running two cabs from the RT250 in stereo mode does that mean one side is 6L6 & the other EL34 or is it a combination of the two sides split evenly to each cab?
The first choice is correct... when in stereo... one cab will be driven by 6L6's, one cab will be driven by EL34's.
--B
You can also load the same tube type into both sides if you want a consistant sound on each side.
