qbclub13 said:
goldwing68nv said:
+1 on the GRAIL...but,with an o/d pedal "boost"!!!
When boosting the grail what do you set the grail gain to? I love the tone Im getting from a boosted brahma with the cusack screamer but I cant seem to dial in a tone i like with it in front of the grail.
with an o/d pedal boosting the GRAIL module,i have the "gain" level,on the module,set between 12 and 1 o'clock max(no more or the "tone" gets tooo tight & thinned out).you also may have to cut the "treble" knob,on the module,back just a notch.as far as the o/d pedal "settings" go,i use a BBE Green Screamer with the control knobs "set" at: LEVEL=all the way up ...TONE=halfway(or neutral) ...GAIN=all the way down ...i use this pedal "setting" for both the GRAIL and my BRAHMA module,with great results.these two mts modules dont really come to life until their "boosted",but then when they are...watch out!!! btw,keep in mind that different guitars,pickups and cab speakers will vary the "tone",quite a bit...good luck!
