M4 - the sounds of silence.
Sorry I didn't see this thread sooner - been too busy with my CD yada, yada. Anyway, it sounds like there is a remote chance you may just have your M4 in the bypass mode. There is actually a MIDI channel that turns them all on bypass. I can;t rememeber which it is, andI'm away from my rig. To remedy this, you can send a MIDI Program change 1-8 to it and you should be up and running. For it to receive the MIDI info, make sure the DIN switch on the back is set to either OMNI (recieve on all channels 1-16)) or the specific one you know your controler is sending. This may be it?
