V2+RA412XLT Cab
4X/MS
Hello!
I have bought a Randall V2 Amp and the RA412XLT cab today.
Since the RA412XLT Box has got a maximum Power of 240 and the V2 delivers 400W @ 4Ohm i assume that the speaker output of the amp must not be connected to the 4Ohm Mono Input of the Cab.
Now i wanted to ask in which way i can connect to Head and the Box to get an optimal result?
Can i use 2 Cables for the both 8Ohm stereo inputs on the Box or can i only use the 16Ohm Mono input?
Thank you!
I know you can still run it at 4 ohms, you just got to keep the master at a reasonable level to not kill the cab. I know on my V2 halfway on the master was loud enough to play a show without a mic on it.
