KH-2 capacitors
Jaded Faith
Hamilton, NJ
Anyone know what the stock C3 on a KH-2 is? Or what brand those square plastic rectangle shaped caps they used on the KH-2 are for that matter? I can't figure out how to read the info on them to make heads or tails of them. Want to crank my KH-2 a touch tighter and need the starting value so I don't have to guess. I'll probably go with 0.001, but 0.0022 is possible too since I use it for crunch tones more than high gain. I have used my KH-2 and KH-3 at our last 4 practices and they sound really good...until I stuck my KH-3 next to my Pete-modded Recto this morning! :cry:
eery parallel to me!
I believe the stock is 0.0022uF but I'd have to check to be sure.
I think you are right. Swapped out the C3 on Saturday morning for a 0.001 Orange Drop and I like it alot. Did the trick nicely.
