Has anyone ever retubed the RM100, if so what tubes did you use and did it sound better after the tube job?
The reason I ask is due to the fact I have the Ruby 6L6GCMSTR's in mine and I don't think i like them to much and the stock EH 12AX7 preamp tubes. I was thinking of either 6CA7's or KT77's for the power tubes. Or the new reissue Mullard El34's. Preamp tubes I am not sure what to do on those. Maybe the new Tungsol 12AX7's or an RFT in V1 and Tungsols in the modules.
By the way is the preamp tube that is right behind the input jack V1? My guess is that it is the V1 tube. Then the two preamp tubes behind that are just tubes for the effect loops right.
So how would all this stuff work in this amp. What position are the preamp tubes in the modules considered? What tube posistions are the two preamp tubes that are in front of the effects loop, V2 and V3 I suspect. Or are they V4 and V5 and the tubes in the modules are V2 and V3. Could someone clear this up for me please.
Thanks
Thanks
