Salvation Mandarine Stonerverb *new higher gain sample*
salvation
EU, Czech Republic
Hi,
look and listen my new modification.
Mod based on Orange Rockerverb amp.
This module is able to do "from clean to mean", from shimmering clean, through signature crunch (as you hear on the soundclip) to massive overdrive.
After all previous more or less metal oriented soudclips, I asked Hyenik to make something little different, different music genre.
But be sure, you can play metal with that module too!!
For example Jim Root of Slipknot uses original artwork :wink:
listen here: http://soundclick.com/share?songid=7515602
some pics:
Anthony
sounds KILLER!!
what mod did you start with, or would you recommend sending you for this work?
audioholic said:
sounds KILLER!!
Thanks to :.
hyenik - guitars a bass, hany_es - drums a mix
I used XTC module.
Any higain or midgain module would work with the same result.
Anthony
audioholic said:
how would this module do for leads?
This module can do leads very well.
Due to special gain control, which controls gain on two places in curcuit simultaneously, the Gain knob has very wide range.
Anthony
Hyenik from that forum-my friend from my country-is very picky customer.
He always wants something special.
He is owner of my lower gain Mandarin AD module.
When he offered Stonerverb, he wanted somewhat different look.
So, here it is:
For some reason i can never view the pics in your posts???/ Anyone have any ideas why?
problem with your browser ;)
I had the same. But I dont remember what exactly was .....
Well, I received my Stonerverb module today and I must say, due to lack of better words, it kicks *** :D
It goes from a very nicely flavoured clean to a very distinct sounding hi gain tone. It really sounds Orange-y, great work from Salvation! I tested mine in my Lynch Box (E34L powertubes) together with my Washburn N5 (all single coil, ST5K pickups) and you can get an awesome tonal spectrum with it. Keep up the great work, Anthony, I'm curious for the things to come :D
Today I'm going to try it with some of my humbucker equiped guitars, I'm really looking forward to that!
Added new sample.
Shows versatility of Stonerverb modification.
Sample is played on 1st - lower gain channel only.
First some clean strumming, little funky chords and full gain juicy clean crunch.
Look forward to samples of higher gain dirty channel.
I think you cannot imagine how much sounds is hidden in this little orange animal:wink:
http://soundclick.com/share?songid=8148554
Anthony
SALVATION
played on fender japan strat (probably 1990)
first and second part - neck pickup, gain on module about 4
third part - bridge pickup, full gain (but clean channel :)
This is first showing, that we didn?t lie about "FROM CLEAN TO MEAN"
Beware, Stonerverb doesn?t mean only QOTSA!!!
