Lynch Box master
MYDEMISE
Detroit burbs
Is there a difference in the Lynch Box master and the RM100? I read somehere about the master being like a variac or hot plate? Is the power section of the Lynch Box just a different voicing of the density pot's frequency or something more dramatic? Thanks
The MTS works like this:
* your modules have a gain + tone stack + channel master (pre-FX loop)
* you have Density + Presence + Master Volume
* the master volume is Pre-phase Inverter
This configuration allows you to open up the amp master and regulate your volume using a combination of channel gain and channel master volume.
You do not need a Hot Plate or other attenuator with this amp.
The master volume is not like any kind of variac or attenuator.
I run my master at noon - 1:00 and my channel volumes at around 10:00. That's loud enough for the studio. For a gig I'd open up the master more and work with the channel volume.
Turning the channel masters too high can cause clipping in the FX loop. Go only as high as needed.
You are very knowledgable. Thanks for the info. I figured that was the case but I have not recieved the Lynch Box yet and wondered.
